It is currently Fri Dec 26, 2025 6:50 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: ecucontrol problem
PostPosted: Fri Apr 02, 2010 5:47 pm
After I get the notice about the AFR tables not loading, I click ok, and get another error message: No MTS ports available.
Granted, this is not hooked up the a car with the ignition on, im just on my laptop.
So, how can I get the AFR tables to load, and is the pop up of no mts ports availalable an issue?
I am trying to test what I can today before we hook up and try and figure EVERYTHING out, tomorrow, on the car.
Thanks in advance to anyone able to help :-)
PostPosted: Sat Apr 03, 2010 2:17 pm
the no MTS ports message is because there are no extra ports at the time of startup (ie, nothing plugged into the usb for datalogging). it will go away when you plug into the ecu or another device...
the other error...thats the first i've heard of that. is there an error number associated with it? what are you doing exactly when it pops up? is it when you click open target AFR or when you click on a certain file?
PostPosted: Sat Apr 03, 2010 2:26 pm
I uninstalled everything and reinstalled. Now it is working, or at least opening lol. Not sure where the error was, but its good now.
Thanks for your reply!
PostPosted: Fri Apr 16, 2010 6:15 pm
i get an error message when i try to run TE 3.1.10 when i run TE version 3.1.2 its fine i have the same error with every version after 3.1.2
PostPosted: Sat Apr 17, 2010 12:07 pm
ownload the resource files, http://forum.pgmfi.org/viewtopic.php?f=60&t=15233, or just msinet.ocx) and place the file in your system folder (most likely c:\windows\system32) then register it. to register the file, click start>run then type in regsvr32 c:\windows\system32\msinet.ocx and press ok.
this will vary depending on your version of windows and where your system folder is located...that should fix the problem.
you can also take msinet.ocx and place it in the same folder as your turboedit.exe file...9/10 that will work also.
PostPosted: Sun Apr 18, 2010 7:12 am
i found a much easier way rather than fight for TE to be on my vista based desktop so i can learn, i got a free laptop from a neighbour with xp i fixed the power input port and TE and Ecucontrol work awesome nut thanks for the help
Users browsing this forum: Baidu [Spider] and 50 guests
