It is currently Wed May 22, 2024 11:29 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 45 posts ]  Go to page 1, 2, 3  Next
 Post subject: 3d view plugin
PostPosted: Fri Aug 26, 2005 5:48 pm
hi all
made a 3D view plugin, please feedback if this works for you, if you like it, want a better version of this, an edit capable version, etc...
pierre
CHECK THE LATEST VERSION BELOW
PostPosted: Fri Aug 26, 2005 10:11 pm
added : sizable window, background color select with registry save, copy maps to clipboard in meta values (gives a pic if paste in image editor, gives text values if paste in text editor), map view mode menu, windows menu
PostPosted: Fri Aug 26, 2005 10:42 pm
I install it and it says everything succeded, but it doesn't appear on the Plugins menu. I tried uninstalling it and reinstalling it, same thing. Any ideas?
PostPosted: Fri Aug 26, 2005 10:57 pm
same here
PostPosted: Sat Aug 27, 2005 7:46 am
probably cause you miss the mschart.ocx
I tried to build a small install package...give it a try...
package removed : too big and useless
PostPosted: Sat Aug 27, 2005 7:52 am
btw, I have the exact same problem with the "ecucontrol" plugin !
PostPosted: Sat Aug 27, 2005 8:28 am
still
:cry: :cry:
PostPosted: Sat Aug 27, 2005 8:58 am
I updated the package, please try to dl again and reinstall
I also modified the plugin, removed uneeded reference, may help out
I could not upload the full install, it is too big
Sorry about that guys, I wish it could work out for you !
Did anyone get it to run ?
*** THIS VERSION IS FOR TE 2.0.x ONLY - FOR TE 2.5.x SEE NEW VERSION BELOW ***
File comment: with uneeded reference removed
pgmfz3.zip [17.02 KiB]
Downloaded 1468 times
PostPosted: Sat Aug 27, 2005 7:25 pm
I tried both the update and the new package, neither show up on the list still.
PostPosted: Sat Aug 27, 2005 8:25 pm
sure you use version 2.0.11 of TE ?
the plugin does NOT work with version 2.5.2 !
I don't know why, tough.
:roll:
PostPosted: Sat Aug 27, 2005 11:12 pm
Ah, well that would explain it. I'm using 2.5.5. I don't have the 2.0.11 files to test with, maybe someone else does?
PostPosted: Sun Aug 28, 2005 4:18 am
civwic, please, please do a 2.5.5 plugin. I'd love to try it and help out debug
PostPosted: Sun Aug 28, 2005 9:32 am
I'm using 2.5.5 and I have the same problem!!! there's definately an issue with your program.
PostPosted: Sun Aug 28, 2005 10:32 am
guys, for now, there's nothing I can do for version 2.5
I have the 2.0 API guide file but I don't have it for later version
(maybe it is not public anymore ?)
It's not an issue with my program really, plugins are not cross version compatible, not my fault !
If I get the proper info, maybe I can work it out but until then...
here's a screen shot...
(edit : smaller screenshot)
PostPosted: Sun Oct 09, 2005 7:49 am
New version now works with TE 2.5 !
check it out...
I will soon add new funky features to Z3D so...stay tuned !
Special thanks to Synoptic (EcuControl) for the help on the 2.5 API !
This version was left online in case newer one gives problems...but you'd better check it out, it has a lot more features !
(I will remove this version as soon as new one proved to be ok)
to jump to the next version post :
http://forum.pgmfi.org/viewtopic.php?t=6935&postdays=0&postorder=asc&start=28
File comment: use the newer version !
pgmfz4.zip [15.92 KiB]
Downloaded 1447 times
