It is currently Thu Apr 25, 2024 4:35 pm
 Post subject: Rebuilding old Ecm
PostPosted: Mon Dec 30, 2019 10:49 pm
Hi guys, i replaced the ecm in my 95 accord ex Vtec, because it kept throwing me code 9s even though i had changed the distributor like 3 times. Anyhow, in an electrical test where i probed the wires for the bad sensor, it was giving me really high resistance on the multimeter, which both my honda instructors said was either rust or a bad component, leaning more towards bad component as both me and my instructor couldnt find any rust. My question is can i find the bad component(s) and replace them, and what would they most likely be?
note: I did search the forum and someone had said IC17 TA8903 but im not sure if that is correct or not
 Post subject: Re: Rebuilding old Ecm
PostPosted: Mon Mar 09, 2020 5:00 pm
we dont have a schematic for that specific ECU...
you will have to trace out that input to where it goes... probably one of the HIC daughter boards, or one of the larger multi-transistor arrys.
Users browsing this forum: No registered users and 11 guests
