the maps are ok, the rest of it is crap due to the limited OBD2 support of Crome. This may suck but it's 100% better than no support.
(it seems that you don't have the OBD2 handler based on those values)
Open this bin in Crome.
Use Export Tables under the file menu to a file of your choice.
Close this bin.
Open a new P30-203 map, manually adjust the map sizing so it matches the P2T maps.
Use Import Tables under the file manu, locate your file.
adjust your options to fit your engine.
OR
since your VTi has the B16a, use the P30-203 map the way it is.
Both methods will give you a decent base map for your engine.
the first method will be closer to your stock setup though.
EDIT: I tried it myself and the export/import option wasn't as easy as I thought it should be.
Here's what I came up with. I copy/pasted the cells into excel and filled in the missing cells by averaging the two surrounding cells.
You still have to adjust everything in the options tab to your liking but at least the maps are there in usable form.
