It is currently Sat Oct 04, 2025 11:40 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 12 posts ]
PostPosted: Thu Nov 24, 2005 12:04 pm
I am looking at the crome maps and such and i understand just about all except mbar. i know its what the map sensor is sensing( i think anyway) but i dont understand more than that can someone give me a quick run down on how it relates in tuning?
PostPosted: Thu Nov 24, 2005 2:11 pm
mbar is a metric standard, like in/hg or psi. it is in absolute as opposed to negative/positive
PostPosted: Thu Nov 24, 2005 4:49 pm
so if i am understanding correctly...
if my car is at 8 PSI its at what mbar? or is mbar only for vacume?
PostPosted: Thu Nov 24, 2005 5:02 pm
millibar is 1 thousanth of a bar, so 1000millibar = 1.0 bar
8 psi BOOST is 1 bar + 8psi, there is 14.5 psi in 1 bar therefore 8 psi is arond 1.55 bar of manifold pressure (absolute pressure) OR 1550 millibar.
PostPosted: Thu Nov 24, 2005 9:10 pm
wait.. 8psi is 1 bar? or 14.5 psi is 1 bar?
PostPosted: Thu Nov 24, 2005 9:14 pm
1 bar = 14.5 psi (use google, it does unit conversion as well as link to sites that do it too).
http://www.google.com/search?client=safari&rls=en&q=1+bar+to+psi&ie=UTF-8&oe=UTF-8
PostPosted: Fri Nov 25, 2005 7:05 am
He is converting his units man...... You can't add 1 pound and 1 killo....
1bar + 8psi = ?
here's how it goes:
we first convert bar -> psi: 1bar = 14.5 psi, so the above becomes:
14.5psi + 8psi = ? well, it's = 22.5psi
Now, we'll go back to bars: 22.5psi / 14.5 = 1.55bar
and to millibars: 1.55bar * 1000 = 1550mbar
:wink:
PostPosted: Fri Nov 25, 2005 10:39 am
1bar + 8psi = ?
here's how it goes:
:wink:
thanks man.. so now i have that part... so how does that pertain to tuning ? in crome the left side is mbar and the top is fuel . trying to learn how it works.
PostPosted: Fri Nov 25, 2005 11:01 am
In CROME the columns show the vacuum, and the rows show RPM.
So, if you are at idle, the engine is at low RPM, and since the throttle is closed, there is high vacuum. High vacuum = small mBar reading, so the ECU will be using the values from the upper ( low rpm), left-hand ( small mBar) portion of the maps.
At WOT, just before you hit the rev-limiter, there's high RPM and low vacuum because the throttle is open, so this time, the ECU will be using values from the lower ( high RPM), right-hand ( high mBar and low vacuum) part of the table.
If you were in this WOT situation and totally released the gas pedal, the revs would start rapidly falling. Right after you release the pedal, the ECU will see high revs and will stay in the bottom rows, but since you've closed the throttle, the vacuum wil become high, and the ECU will move to the left columns. So the ECU will be using value from the lower, left-hand side of the maps. And as you slow down with the gas released, the ECU will be staying in the left part of the map and slownly moving from bottom to top, as revs are decreasing.
PostPosted: Fri Nov 25, 2005 11:24 am
Very clear and beautiful explication, I guess this need to be wiki-ed :wink:
PostPosted: Sat Nov 26, 2005 3:14 am
Agreed!!!!!!!!!!!!!! TY awsome explanation
PostPosted: Tue Nov 29, 2005 12:26 am
wow, you're right, that was very well put!
Users browsing this forum: No registered users and 19 guests
