It is currently Wed Mar 03, 2021 10:22 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jun 10, 2005 1:17 pm
Board works fine for me, its the cable they sell that doesnt. Anyone got a driver that actually works it properly.
PostPosted: Fri Jun 10, 2005 2:32 pm
The cable should be a straight forward cable (null modem). Any null modem cable will work with got speed board as well as the one i've built. So, no drivers required.
PostPosted: Fri Jun 10, 2005 5:44 pm
It shouldn't be a null-modem cable..
it should be a cable, specifically, with pin2 connected to pin 2, pin3 connected to pin3, pin5 connected to pin5 male to female. no other pins necessary..
PostPosted: Fri Jun 10, 2005 6:30 pm
Its a USB to serial cable...
PostPosted: Fri Jun 10, 2005 10:44 pm
Isn't that a null modem cable? :oops: :oops: :oops: :oops: :oops:
PostPosted: Fri Jun 10, 2005 10:48 pm
'null modem' refers to a connector where
CON1   CON2
2      3
3      2
4      6
5      5
6      4
7      8
8      7
Null modem cables are commonly used with PCAnywhere to link 2 PC's together to transfer files, 'sans-modem'
Go to RadioShack website & look it up..
PostPosted: Sat Jun 11, 2005 2:17 pm
Oki, my error. :D
I just bought an extension db9 cable... and in the package one could read "VGA extension cable DB9M-DB9F" :D :D :D :D So, how can we trust those guys ?
One can always make his own Xtension cable... Just getting a db9m and a db9 f conectores, and solder an apropriate cable tehre. :D
Anyway tkx for the info, Itdannear
Users browsing this forum: Bing [Bot] and 5 guests
