It is currently Fri Mar 29, 2024 5:04 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 46 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: EcuControl Wish List
PostPosted: Fri Mar 11, 2005 9:44 am
Please list the things that you need or would like to see in EC5. Please dont list any bugs use the Beta thread for those. We may not be able to get everyone's goodies but we sure will try...
Thanks,
Damion
PostPosted: Fri Mar 11, 2005 9:14 pm
ability to make own guage faces!!!
and ability to maybe move around guages
this woudl make it alot easier since my idea is to run a dual display on 2 small LCD's instead of a cluster...
but the ability to skin the program like winamp would be awesome!!!! that woudl make me happy for now!
PostPosted: Wed Mar 16, 2005 6:46 pm
Scrap that being silly, just a data output...no chance off ECU Fault codes coming out :(
PostPosted: Wed Mar 16, 2005 7:16 pm
cel detector...so if the computer throws for instance a code 10 itll show you that the computer is throwing code 10 and its the IAT or whatever.
PostPosted: Wed Mar 16, 2005 7:50 pm
the right speed
the guage in EC that shows speed starts at 60km/hr
if its changed (just the displayed #'s) and start @ 20km/hr it will be accurate
PostPosted: Wed Mar 23, 2005 2:53 pm
Man we must be doing something right... havent heard much on this thread.
PostPosted: Thu Mar 24, 2005 12:23 am
Just get t logging correctly.. Take all the generic formula's out, and put the GOOD formulas in.
PostPosted: Sun Mar 27, 2005 12:57 pm
Maybe it would be nice to have a switchable Vac/Boost dial face (like Speed is) so it can support 2, 2.5 and 3Bar map sensors :)
PostPosted: Sat Apr 09, 2005 5:11 pm
Id like to see the adjustable tps threshold and sample rates.
Also how about a data graphing tool?
PostPosted: Wed Apr 13, 2005 3:27 pm
map tracing while on RTP screen
dont know if its a hardware or software problem, but maybe we can make the program use more RAM out of the laptops, so the reponse on the guages are faster and more accurate
PostPosted: Mon May 09, 2005 4:50 pm
Hows about making it compatable with the PJ1 ecu??? thats if it isn't already. also the ability to change the speedo reading from KMH to MPH with the reading up to 150mph.
PostPosted: Tue May 10, 2005 2:21 am
double click the speedo, will turn to MPH, goes up to 160mph. you shouldn't need it any higher than that :twisted:
 Post subject: TPS calibration
PostPosted: Wed May 11, 2005 3:32 am
At my b16a2 p30 209
ECUControl shows 0% until 15% of real angle, at the 100% it shows 93%
I was almost disassemble throttle body to fix the sensor, but measure voltage manually first (it was OK).
Maybe some kind of calibration or coefficient setting should be added.
PostPosted: Thu May 12, 2005 2:19 am
high and low warnings, which can be set for each gauge it can be usefull
