It is currently Tue May 14, 2024 2:00 pm
PostPosted: Sat Apr 08, 2017 2:32 pm
Ok guys so I bought a ecu out of a Gsr that had no sticker on the outside thinking it was an obd1 p72-a01 ecu but when I brought it home and opened it up the inside sticker shows p30-a00. I can't tell if these stickers have been tampered with since the p30-a00 sticker is lifting on one corner so I'm not too sure what I have can soneone help me figure out how to tell them apart and make a positive ID on this ecu.
PostPosted: Sun Apr 09, 2017 3:53 am
It seems to be a real P72 obd1 ECU :wink:
http://ff-squad.com/tech/ecu/obd1.p72.check.jpg
PostPosted: Sun Apr 09, 2017 9:06 pm
Thanks for the tip seven40
PostPosted: Mon Apr 10, 2017 10:35 am
even if does checkout, it has been 'touched' in some way or another.
removal of the outer sticker suggests either a case swap due to damage/corrosion/removing_mods (ie switch mounted in case) or an attempt at hiding something.
Inner sticker being incorrect suggests a lot more of the latter.
this may not be a bad thing to your goals, simply treat it as such.
