How to use:
Plug in your cable, download driver, go start menu>control panel>device manager>continue>ports(com&lpt), set your baud rate to 38400(or closest) and make note of com port number.
Now open free log, go tools>setting and select correct com port, and at the top select crome protocall 2(I think it says QD2), or curi's D/L. all other setting should be correct. Now jump the white wire to the green wire on your cable( I like to use an extra piece of soldier as a jumper). Now click the button that says "loopback test". If your com port is set up correctly, you get a passed message. Now disconnect the white from the green, and connect to the ecu as shown in the picture. Now click the "sanity check" button. If everything is set correctly you will get a message like ecu detected or something like that(sorry I don't remember exact message. If you get this message, have happy data logging, if not, let me know, I wrote this off of memory from a couple years ago, I may be forgetting something.
Driver below...
