It is currently Thu Apr 18, 2024 1:08 pm
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Thu Apr 28, 2011 7:09 pm
confirmed that I get the same win 7 error when I install turboedit 3.2.2.In my case I have a small 7 inch laptop (yes! 7 inch kohjinsha laptop) and windows xp is acting up so I had to use win 7.My asus 901 is great with windows xp but this 7 inch kohjinsha has touchscreen as well and you can turn the screen and becomes a tablet!
PostPosted: Tue May 24, 2011 2:44 pm
DO NOT TUNE YOUR CAR ON A WIN7 LAPTOP!
I almost got a heart attack the previous night!!
I got a nice 7 inch touchscreen laptop with win7 on it, I thought why not use that to tune the car.Installed the software and drivers (although some error occured at the TE installation, I said forget about it).....then plugged everything up and loaded a bin to my ostrich.....then hell broke loose!.......turned the key, solid cel, loaded the bin again, solid cel, loaded my factory map solid cel!I`ve put my factory ECU on and everything was good.I thought Ostrich was fried.Everything seems to work ok except Ostrich.I`ve verified that it writes and reads fine with my GQ-4X but no matter what I was doing I was still getting a solid cel....then I had an idea of resetting it with the DORSET utility from moates....SUCCESS!It started working again....but lesson learned......do not do any tuning with windows 7.End of story!
PostPosted: Tue May 24, 2011 2:49 pm
Um . . . There are several people tuning with TE on 7. I wouldn't necessarily freak out quite that much.
PostPosted: Wed May 25, 2011 1:37 pm
well, the TE installation is giving me some errors (not the missing files that we need to register, it`s a different error) plus it messes with my ostrich.It`s a dead givaway to me that something is wrong with either the installation or windows 7.I`m staying away from it and I`m reporting just in case somebody ends with a solid cel and doesn`t know what`s going on.
PostPosted: Wed May 25, 2011 2:32 pm
Cool.
PostPosted: Fri May 27, 2011 6:01 pm
I have used nothing but WinBlows 7 Professional on a laptop to tune my car using TE 3.2.2 - I have a three port USB hub (non-powered) connected to my 14.7 wideband, my Ostrich and a USB to serial convertor to talk to the ECU and I have not had an issue. Data logging both the ECU and the wideband and uploading/downloading to the Ostrich.
What Tablet PC do you have? Is it a dual boot Android tablet?
Kirk
PostPosted: Fri May 27, 2011 8:15 pm
It`s a Kohjinsha SC3 (7 inch touchscreen) with Windows 7 Ultimate.It might be something simple like a corrupted driver or something, but I`m scared to plug it in to find out! I might install a fresh copy of windows xp on it.Until then I`m using my Asus 901 for tuning.
Also, how did you fix that STDOLE2 error that appears when you install TE?I get that as well.
PostPosted: Fri May 27, 2011 8:28 pm
Hmmm...didn't get that error - I am running just Blows 7 without any service packs installed...I am not familiar with the "Ultimate" package...perhaps they have "Ultimately" screwed you? :idea: Just kidding - not a fan of the Bill Gates bloatware but in some cases you just have to do what you do...
Thanks for the info on the tablet, but, is it a dual boot system?
Kirk
PostPosted: Thu Jun 02, 2011 7:20 pm
Kirk
http://www.youtube.com/watch?v=sfaH4Ok4Bjo
Here you go.It`s not dual boot.It`s a windows mini laptop (was $1000 when new) got it for $200!It`s going to be excellent for tuning (has a touchscreen as well).
PostPosted: Sun Sep 11, 2011 9:59 am
I got around the problems with active X and the plugins with just "right click, run as administrator" on TE.
I'm on Win7 also.
But I am having problems with connecting to ostrich, not sure if that has anything to do with win7 though. No problem i Crome.
PostPosted: Mon Nov 25, 2019 6:06 pm
Hi.
In 2019 use all OBD0 soft WITH right click, run as administrator
When you install software right click, run as administrator
When you install ECU Control same thing.
Thank
