It is currently Fri Dec 26, 2025 10:17 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Nov 20, 2009 11:06 pm
fastcrxsi90 wrote:
yes...change the read interval (originally 4ms) to 1000ms and see what happens. it will in essence "read" from the ostrich much slower, hopefully giving it enough time to respond.
i use an ostrich 2 and it has worked for me every time.... :?
I tried 1000,2000, and it still gives me an error that it is an incompatible rom. I save it anyway and I can not open it. I'm using a DELL with a 400mhz processor and 256mb of RAM on XP.
you have the switch on the side of ostrich to 28 pin, ( dam I can't remember the other switch). the ribbon cable with the chip on it connected to the ecu and ostrich, right?
I'll just keep messing with different things and combination's I guess.
PostPosted: Fri Nov 27, 2009 1:50 pm
I just tried something crazy slow like 500ms read speed and it still identified the rom as not compatible with TE???
PostPosted: Thu Jul 29, 2010 4:36 pm
I have the same problem.I`m using an Asus eee pc 901 though.Help?
PostPosted: Sun Aug 01, 2010 6:26 pm
yeah, I've yet to get this to work on my laptop...... It works on my pc, so I know it's not my ostrich, but I'm still stumped. It's really not that big of a deal though, I just save very very often, ie after every change.
PostPosted: Mon Aug 02, 2010 11:33 am
It`s not a big deal.Uploading works just fine, and that`s the crucial part!When you are done with your tuning just save everything in turboedit, close it, open EMutility and retrieve your file from Ostrich.
