It is currently Fri Dec 26, 2025 12:41 am
PostPosted: Mon Feb 26, 2007 5:59 am
alright i know ive released a ton of stuff. welp i decided to go back to the plugin and see whats going on. i think everything in the plugin is simple to understand. under the autotune tab...there is a button that is labeled adjust fuel maps. in short highlight the cells in the NEW FUEL VALUE tab and click that button. it will copy those cells over to your current fuel map. by clicking the load target button that will fill the target afr for each of your cells that you have desired to help autotune for you. i included a file titled "table" which is an example you can load and change if you wish. calibrating your tps should be quite simple. once hte car is on click calibrate and view what the button says. basiclly dont give any throttle and itll make that your 0% and then give it full throttle for a second and itll make that 100% sorry for the crappy little readme here bit tired but i hope a bunch of you folk do test and let me know what issues there is and what i need to fix/add as im willing to do this ASAP just need some testers. thanks guys
PostPosted: Thu Mar 29, 2007 1:17 pm
25 downloads a no replys on how it runs? :(
