It is currently Fri Dec 26, 2025 12:40 am
Post new topic Reply to topic  [ 5 posts ]
 Post subject: LogWorks Plugin
PostPosted: Sat Sep 15, 2007 8:29 pm
This will be the place for my LogWorks plugin that ive been working on. Please try it, and if you have any questions/comments/requests...please PM me and i will post your PM in this thread (since this group is semi-locked).
if you run any product from innovate, connect this plugin...then start logworks and all your selected sensors will be in logworks.
read posts below for updates
v.1.0.7
-added ability to log channels in logworks
-tested with logworks2 (may also work with logworks3)
-user defined channels
-metric or standard units
feeling generous?
find the changes useful?
have a special request?
throw me a couple bucks to help pay for vb6...
or just donate to the cause @ pgmfi@pgmfi.org
Donation List :shock:
9/24/08 - PGMFI - $19
2/21/09 - guest0001 - $5
2/23/09 - esi42 - $10
3/25-09 - turboD15 - $5 & chipped PM6
4/6/09 - The Acid Beaver - $20
5/30/09 - sanimalp - $15
6/6/09 - hondaworkshop.com - $10
10/6/09 - guest0001 - $2
11/27/09 - clwtwizted - $15
1/1/10 - guest0001 - $5
1/6/10 - Walterronny - $15
1/7/10 - kablammyman - $5
4/18/10 - Aragorn - $20
4/21/10 - singleslamhp - $20
5/14/10 - mazdarcing - $10
6/17/10 - fuse - PR3 ecu
8/2/10 - sophocha - $10
8/31/10 - oldmonte - $40
8/31/10 - a9turbo - $10
10/11/10 - jense - $10
10/21/10 - patprimmer - $20
2/3/11 - beboo - $30
2/12/11 - rich777 - $10
2/27/11 - gtpilot - $100
4/21/11 - steinar - $20
7/9/11 - generallee01 - $40
7/27/11 - BladeSoul - $20
10/5/11 - 90zcrex - $25
12/20/11 - RiB'$ - $30
3/9/12 - xsnsx - $75
3/27/12 - Zoltan - $50
8/6/12 - *anonymous - $5
6/8/13 - jbretthowell - $5
9/14/13 - shadow032 - $10
3/30/14 - riverrunner06 - $20
4/5/14 - DAQS - $10
10/13/16 - McAwesome - $20
PostPosted: Mon Sep 24, 2007 7:30 pm
v.1.0.8
-fixed map value, now logs inHg for vacuum and psi for boost
-works in logworks 2 or 3
-map fix is good for stock map sensor, if anyone tests this we can verify it works for other sensors
PostPosted: Mon Oct 01, 2007 6:57 pm
please make sure the the downloaded file is named logworks.dll before loading it into TE. if its named logworks_622.dll, etc...it will cause an error... :?
PostPosted: Fri Oct 19, 2007 4:17 pm
v.1.0.9
-fixed baro sensor values for metric
-added the option (under settings) to auto start logworks on connection
-fixed menus
-few other small visual additions
i cant really think of much more to do to this, if you have any suggestions or requests...let me know. :wink:
 Post subject: Re: LogWorks Plugin
PostPosted: Sun Feb 10, 2008 5:27 pm
v.1.0.10
-added support for 2.5, 3.0 and 4.0 bar map sensor logging...use with TE 3.1.2 or higher.
-added row and column logging into logworks, incase its needed for anything
Users browsing this forum: No registered users and 4 guests
