It is currently Thu Apr 25, 2024 8:47 pm
PostPosted: Thu Apr 24, 2014 5:22 pm
I am running ng3 with TE3.2.2. Trying to disable the O2 sensor CEL, but I still get the CEL1 even after setting CEL1=0 in the 'check engine light' tab under 'ROM Properties'. For what it is worth, I have also set 'o2 options' to 'off' in the 'general options' tab. Any thoughts to what I am doing wrong?
ng63_final_(5F) PM6stock_shiftoff_ launch4000_rev7200_o2off.bin [32 KiB]
Downloaded 1105 times
PostPosted: Sun Aug 17, 2014 3:11 am
I get the same problem. It takes a while for the error to appear though and it only happens when the engine is hot and in gear coasting.
I think its an inherent fault and ca never be truly disabled.
PostPosted: Tue Sep 16, 2014 11:58 pm
same problem here :cry:
PostPosted: Wed Jun 01, 2016 2:37 am
has anyone fixed this problem?? I just recently had to re-install TE on another computer and Im having this issue
