Hi!
Just tried out Turboedit for the first time. I am familiar with Crome since before, and my ostrich and datalogging Cable are working fine with crome. I have the same com port settings and so on in Turboedit as the device manager. At first, I got connection with the Ostrich, and I could "burn" directly from Turboedit to the ostrich as you are supposed to do. But, when I open the ECU Control plugin, and try to connect I get a error message: "Com port 6 is not available" or something like that. But I have the datalogging Cable to com port 6 in both Turboedit and device manager. Then I tried to change a little in the com ports in the device manager, and tried to datalog again in Turboedit and it worked!! Perfect, I thought. But now the Ostrich is no longer connected and I can't connect it again at all? I get a message that says "CommX error - There are no available comm ports on this computer" ?
I am using 2(!) of the 9 com ports on the computer, I don't get it. I have the latest versions of both Turboedit and ECU Control.
Should I try with a older version of Turboedit or something?
Thanks in advance. Best regards, Jim.
