It is currently Fri Mar 29, 2024 12:43 am
PostPosted: Sat Jun 23, 2012 1:24 pm
HI all,
I just got my MTX-L WBset and a DKU5 cable.
I used TE in the past to tune my car and others... but now i want to use the ecucontrol datalog.
I installed the plugins which goes flawless on XP, but when i load my binfile i cant open the Ecucontrol.... I can click it, but nothing happends...
plz help!
PostPosted: Sat Jun 23, 2012 9:07 pm
install logworks 3 if not already...post back what happens.
http://www.innovatemotorsports.com/support.php
PostPosted: Sun Jun 24, 2012 1:11 pm
Do I need to hookup the MTX_L wideband set and USB DKU5 cable first to see the ecucontrol plugin popup?
Or just when I click on ECUcontrol pluging (afther I loaded my binfile) it should popup?
Ill start downloading logworks3
PostPosted: Sun Jun 24, 2012 4:19 pm
No.
It will pop up if everything is installed correctly, even with nothing plugged in.
PostPosted: Sun Jun 24, 2012 4:53 pm
ok, it doenst popup.. should i try a older version of TE?
i just installed logworks3. when i open it it says:
No serial port, IMS USB device, or IMS Network device detected.
I Click on OK and the programm opens..
I have the DKU5 USB nokia cable. didnt install the drivers yet... but i guess TE isnt working correctly?
PostPosted: Mon Jun 25, 2012 10:00 am
Read these and try the 6.1.18 installer.
http://forum.pgmfi.org/viewtopic.php?f=56&t=23046
http://forum.pgmfi.org/viewtopic.php?f=56&t=22268
http://forum.pgmfi.org/viewtopic.php?f=56&t=20408
http://forum.pgmfi.org/viewtopic.php?f=56&t=19303
One of the resource files is more than likely not registered correctly.
PostPosted: Mon Jun 25, 2012 11:27 am
read the text on the 1st and 2nd link you just posted.
I downloaded mtssdk.ocx and wanted to put it in my plugins folder and noticed that it was already there.
I replaced it anyway and it fixed the problem.
thanx!
