It is currently Sat Apr 27, 2024 11:17 pm
 Post subject: cel comes on a 3.25k
PostPosted: Sun Jan 29, 2012 5:44 pm
I don't have a good laptop, so I currently have to do tuning the hard long way of bring my ostrich inside my home to use my laptop. anyway, I succesfully uploaded the rom and played with timing. I exported the bin and imported it into the newest bin ng63_final_5 ??? w/ version 3.2.2. I have launch control, boost cut, etc. all off. the cel is set to stock in ROM properties. I even tried changing the rev liming in N to 7413. driving down the road if the rpm go above say 3250 the cel kickon and stays on. no differnece in how it runs, just comes on.
I also noticed that the cel stays on during the key on pre test/main relay cycle. but it starts and runs fine. I even tried reseting the ecu.
 Post subject: Re: cel comes on a 3250k
PostPosted: Sun Jan 29, 2012 5:55 pm
You downloaded an NG65_final5 bin which has the the CEL set as a shift light at that RPM.
You have to download the updated ExtraTables plugin handler and change the properties with that.
 Post subject: Re: cel comes on a 3.25k
PostPosted: Sun Jan 29, 2012 8:18 pm
I loaded the script but I dont see where to change shift points? Is it Rev limit per gear?
PostPosted: Sun Jan 29, 2012 8:21 pm
It is listed under "Dash CEL." If you don't have that listing, you don't have Extratables v1.13.
PostPosted: Sun Jan 29, 2012 9:36 pm
look here ---> http://forum.pgmfi.org/viewtopic.php?f=60&t=20341#p129870
PostPosted: Sun Jan 29, 2012 9:57 pm
ok, derrrrr, I loaded the wrong script. got, a shift light is pretty cool, though if it deactivated in 5th it would work better.
