It is currently Sat Dec 27, 2025 9:03 am
 Post subject: TE and gm 3bar map
PostPosted: Sun Oct 24, 2010 1:21 pm
Is there anyway to run the 3bar gm map with Turbo edit? I see and option for the Motorola 3 bar, is it the same as gm?
 Post subject: Re: TE and gm 3bar map
PostPosted: Mon Oct 25, 2010 8:20 am
which version of TE are you using? 3.2.1 should have the GM sensor in the options...
FYI, the data sheets that i have for the GM vs Motorola (freescale) sensors are almost the same (voltage vs. absolute pressure)...so in reality, the Motorola option should work fine for you.
PostPosted: Mon Oct 25, 2010 6:04 pm
I'm running 3.1.10 but going to download the 3.2.1 right now
thanks
