It is currently Fri Mar 29, 2024 1:01 am
 Post subject: windows 7 64bit issues
PostPosted: Tue Aug 31, 2010 12:56 am
So, I tried to install the latest TE on my laptop, but, the missing msinet.ocx file came up. So, I tied to register the ocx file (I placed it in the system32 folder) , but regsvr32says couldnt find the file (even tho I can see it right there!) I then try to register the one I placed in the TE directory, and it says it loaded, but there was some kind of error.
So, I tried to install the old TE as well as the super old ecuControl stand alone program to help...It did not help at all. In fact, when the ecuControl stand alone was trying to install, it too couldn't register certain files!
Anyway, the funny thing is, the older version of TE (2.5.2) installs and runs fine on that computer. A few things I noticed is that the older version of TE will install in the program files(x86) folder, while the new version installs in Program Files...in other words, the older version installs itself int he 32bit version of program files directory, and the new version does not. I tried to change the install director to the 32bit program files folder, but no dice.
I dont get it...I remember having a few headaches with my desktop machine that has windows 7, but in the end, it works fine...maybe because this version of windows is 32 bit?
Arg, this is frustrating. Any advice?
PostPosted: Tue Aug 31, 2010 8:29 am
im using inno setup for the installer - http://www.jrsoftware.org/isinfo.php
i'll have to do some research into what is going on...
PostPosted: Wed Sep 01, 2010 8:16 am
besides the c:windows\system32 folder, do you have a c:windows\sysWOW64 folder?
from what i've read, vb6 applications (on 64 bit systems) have to be run using the windows on windows emulator... i'll have to read more into this...
http://msdn.microsoft.com/en-us/vbasic/ms788708.aspx
http://community.ingres.com/wiki/ODBC_on_64_-_Bit_Windows
good thing i have a 90% working vb.net rom editor...cause it looks like after win 7 there is no more support for vb6 applications.
PostPosted: Wed Sep 01, 2010 8:22 am
My advice.Ditch Windows 7 64bit and get a netbook with Windows Xp sp2 32bit.Can`t go wrong with Windows xp.You are going to save yourself from a lot of incompatibility headaches.
PostPosted: Wed Sep 01, 2010 10:49 pm
Its not my laptop, its my gf, so I cant just do what I want with it. lol
yeah, that folder exists. I should do some research too.
PostPosted: Tue Oct 02, 2012 9:12 pm
Couldn't fix Hulog to work on win7 x64.
Using x64 driver from http://www.moates.net/usb-device-drivers.html and FreeLog 1.0.7.8.
ECU made at phearable.
Anyone?
Cheers.
File comment: Tried COM from 1 to 6 and lots of different configs.
Users browsing this forum: No registered users and 12 guests
