fastcrxsi90 wrote:
with the romulator do you have to have the ignition on to upload the rom (even with crome and hondata)? did this work correctly for you in the earlier versions of TE?
i did change a few things trying to get this to work correctly, but apparently failed! does the get rom function work for you? i will check the code changes i made and see if i screwed up somewhere...
i used this as a reference for the romulator...as i dont have one to test with.
http://wiki.xtronics.com/index.php/RomulatorWith Hondata and Crome, the ignition must be in the on position in order to upload files to the Romulator. That is just the design of the Romulator, the power from the pin(s) is what turns the Romulator on.
Honestly, I haven't tried an earlier version of TE. Today was our first attempt with using TE to tune the motor. I did not try the get Rom function either.
The only way I was able to do a half way "real time" was by using the Moates.net utility, but I still had to switch over to that program and hit upload again, after making changes and saving the rom in TE.
If you are able to write some code that would make it work, I can supply you with an extra Romulator that I have.
Unfortunately, the car is 80 miles away, so I won't be able to make and changes and report back for at least a few weeks.
