| ecucontrol problem http://forum.pgmfi.org/viewtopic.php?f=56&t=19303 |
Page 1 of 2 |
| Author: | turboed [ Wed Nov 25, 2009 8:41 pm ] |
| Post subject: | ecucontrol problem |
hi ive been trying to learn and what not so I down loaded the latest version of turbo edit and ecu control.my problem is everytime I press connect on ecu control with the ignition on i get runtime error 11 division by zero. I have no clue how to fix this I would really like to so I can datalog. I have searched but no luck |
| Author: | fastcrxsi90 [ Wed Nov 25, 2009 9:50 pm ] |
| Post subject: | Re: ecucontrol problem |
what version of ecucontrol are you using? do you have all the settings filled out...or have the calculations turned off? post a screen shot of the error so we can see what data is filled out and what isnt. |
| Author: | turboed [ Wed Nov 25, 2009 9:59 pm ] |
ok im using ecu control version 1.0.0.i would be glad to post a screen shot but how do u do that. sorry for the newbieness |
| Author: | turboed [ Thu Nov 26, 2009 2:17 am ] |
I just noticed i dont have the most recent one. i downloaded the 6.1.8 and dropped it into the bin and when i try to open it it wont open when u click on the downloaded ecu control. |
| Author: | fastcrxsi90 [ Thu Nov 26, 2009 9:57 am ] |
try the newest TE and newest ecucontrol...i can guide you through that. ecucontrol 6.1.15 - http://forum.pgmfi.org/download/file.php?id=6522 ecucontrol instructions - http://forum.pgmfi.org/download/file.php?id=6449 ecucontrol 5.8.41 (in case you dont have it installed) - http://forum.pgmfi.org/download/file.php?id=6344 TE 3.1.10 - http://forum.pgmfi.org/download/file.php?id=7085 TE 2.5.2 (just in case) - http://forum.pgmfi.org/download/file.php?id=6321 install TE 3.1.10 if you dont have it, then install ecucontrol 6.1.15 (unload your current plugin and load 6.1.15 using the plugin manager in TE). open ecucontrol using TE and post what happens. press Alt + Print Screen keys and paste it into MS Paint, save the file as a .jpg and upload to your post... |
| Author: | turboed [ Thu Nov 26, 2009 10:58 am ] |
ok thanks ill try that and let u know what happens. |
| Author: | turboed [ Thu Nov 26, 2009 11:43 am ] |
ok I already had all those but I reinstalled all them with the copys u posted. I did what u said and loaded the 6.1.15 its in the drop down for the ecu control but when u click it to open ecu control nothing happens. even if u click the ecu control icon on the top panel nothing still happens.Thats after I have opened a rom. |
| Author: | turboed [ Thu Nov 26, 2009 11:53 am ] |
and if i try to use the 2.5 version of turbo edit this is what i get when I try to open ecu control even though u can see I have a bin open already
| Author: | fastcrxsi90 [ Thu Nov 26, 2009 7:48 pm ] | ||
| Post subject: | Re: ecucontrol problem | ||
make sure you have ecucontrol 5.8.41 installed (you dont have to use it)...and make sure you have all the support files in the same folder as ecucontrol.dll. i believe if echartcontrol.ocx isnt in the same folder or in the system32 folder...it more than likely wont open. let me know if all the included files are in the correct folder...and if it still wont work. also look here... http://forum.pgmfi.org/viewtopic.php?f=56&t=18836&p=117292
| Author: | turboed [ Thu Nov 26, 2009 11:24 pm ] |
thanks man that did the trick
| Author: | fastcrxsi90 [ Fri Nov 27, 2009 10:10 pm ] |
thats the screenshot i was hoping for! |
| Author: | fredzcrx [ Sat Dec 05, 2009 7:38 am ] |
I'm having problems upgrading from 6.1.11 to 6.1.15. I followed your directions, but the plug-in manager just keeps uploading 6.1.11. I'm not sure that I need to upgrade it though, because 6.1.11 does pretty much all I need so far(I think). I just want to be up to date. Thanks. |
| Author: | move over [ Thu Mar 25, 2010 4:25 pm ] |
I am having a similar issue. I noticed that in your screenshot of the plugin file folder, you have a lot more items and folders that do not exist in mine. I extracted all files from the compressed folders to the same folder under Plugins, installed, then loaded the plugin. Here is a screen shot that I get when I click to open ecucontrol from within TE. NOTE* I do not have the laptop connected to the car. Is this a requirement in order to open EcuControl? I did not think it was; I am trying to familiarize myself with the program a bit before attempting a tune. Attachment:
| Author: | fastcrxsi90 [ Thu Mar 25, 2010 7:22 pm ] |
thats because you have a stock rom open...no support for datalogging on that. try using an ng rom then open ecucontrol...it should work then. i will add some error handling stuff for that so you at least know whats going on... |
| Author: | move over [ Fri Apr 02, 2010 3:04 pm ] |
I finally got it to open. I had to reload the plugin after I opened an ng rom apparantly. however, I can't load the target AFR tables.... I get a pop up box telling me "the specified module could not be found." Is there a trick to loading the values from the excel file into ecucontrol? I also tried copy / paste, but that does not work. |
| Page 1 of 2 | All times are UTC - 5 hours [ DST ] |
