joppez wrote:
5.8.41 is the version. I didnt have turboedit at all, just datalogging, also tried datalog with bre, got connect but it crashed always. I got chip now but next im trying to get romulator working with usb and vista
+ ecucontrol too.
If it not work i got laptop with xp and com port too but its borrowed now so i try with new laptop with vista.
Car is tuned already with bre, but some minor tuning could be helpful. Thanks a lot for ur work!!
if you dont have a copy of the bin in your ecu (and just want to datalog), then you can open TE and create a bogus bin with a 3 bar map sensor (GM and Motorola should be close enough for datalogging)...then start the ecucontrol plugin and go to town... the plugin uses the properties of the rom thats open in TE.
im assuming your running an ng series rom...since you say it was tuned with BRE.
i have heard that TE works with vista, but havent heard anything about datalogging/rtp stuff...let us know if you get it working or not.
*EDIT...sorry, i cant remember if there is a way to change the map sensor with 5.8.41, i will look when home.
