http://forum.pgmfi.org/
TurboEDIT OBD1 Bugs
http://forum.pgmfi.org/viewtopic.php?f=56&t=15608
Page 1 of 1
Author:  mynameistin [ Sun Feb 17, 2008 3:41 am ]
Post subject:  TurboEDIT OBD1 Bugs
Post all the bugs here please....
Author:  JaredKaragen [ Tue Feb 19, 2008 8:48 pm ]
Post subject:  Re: TurboEDIT OBD1 Bugs
runtime error.... does this need any special libraries or service packs?
Author:  mynameistin [ Tue Feb 19, 2008 10:02 pm ]
just a standard install of the old turbedit should fix this
download/file.php?id=6321
Author:  mynameistin [ Sun Mar 02, 2008 7:08 am ]
jared were you able to get it resolved...jsut curious if not i can include the desired .ocx and such files with the zip from now on. if you do reply just let me know with what version. thecurrent is 0.0.3 and o have some good updates that i should release in a couple days...just some addons
Author:  nmarkus [ Wed Jan 21, 2009 1:35 pm ]
first click on obd1 console plugin to load bin file.. second click on obd1 console plugin again to load console.. under rpm rev limit, any rpm below 8000 gives a runtime error '6' overflow. target idle does not allow an entry..
obd1 console v 1.0.0
te v 3.1.9
ecu control v 6.1.15
ibmthinkpad 386
Author:  mynameistin [ Thu Jan 29, 2009 12:03 am ]
i havent touched this in a long time nmarkus. go download TurboEDIT OBD1...its an actual app not a plugin and you may have better luck. i do no remember all the problems
Author:  defrezzer [ Wed Feb 24, 2010 4:48 pm ]
my tables look like that
weird numbers for vac/boost
only see half of the table
where can made my stock maps to Fi Maps.
is there any wire up how to use everything ?
i would like to use Te because i i used for my obd0 cars.
Author:  Sakuji [ Tue Mar 09, 2010 11:16 am ]
Aware that TEs abit old with little support. But the proper way to use it for OBD1 is download and install the main program. Then use the OBD1 hack to use for OBD1s ecus.
Main program: download/file.php?id=6321
OBD1 Hack: download/file.php?id=6498
Used it for tuning. Not bad so far.
Hope this little freebie will get more support
Author:  defrezzer [ Fri Mar 12, 2010 2:39 pm ]
what should this Post say ?
https://www.phpbb.com/
