It is currently Mon Dec 01, 2025 10:54 pm
PostPosted: Sun Aug 01, 2010 6:25 pm
well it only throws code 4 with this ecu
all others are fine
so I know the sensors are ok
tried tracing circuit for any visible problems but nothing
anyone has the fix for this ecu
has the 11F0-1500 board
PostPosted: Fri Aug 20, 2010 1:18 pm
PGMFI Elf
H1C1 is faulty.
PostPosted: Thu Sep 02, 2010 11:20 am
what else does that H1C1 control what about iacv code 14?
can I use one from a p72 ecu looks pretty close??
PostPosted: Tue Sep 07, 2010 1:22 pm
update.........
H1C1 fixed it
thanks again!!
any luck with code 14 on p75-p72 ecu fix??
or code 1 on p30-010 ecu fix?
