It is currently Sat Oct 04, 2025 3:33 pm
Post new topic Reply to topic  [ 12 posts ]
PostPosted: Wed May 12, 2004 3:24 am
Hey,
I have got a knock board from a fellow board member.
i have done some research found some things.
But it was for a p75.
I have never seen a usdm p30. only p30 edm w/o knock board. so i can't compare the diff.
I have read that acongdon have put a knock board in a p30.
i think i have to add r12 and r15 (100ohm).
move the ribon from port a to port b
Calvin
P.s. acongdon please give me some info
[%sig%]
PostPosted: Wed May 12, 2004 7:05 pm
PGMFI Elf
Calvin I have a JDM P30 at home with knock, I'll take some photos for you later
Ev
[%sig%]
PostPosted: Wed May 12, 2004 7:15 pm
You want to know how to add a KS ... just remove it... just thought I'd save someone the trouble of
posting that helpful advice!
On 1720 or 11f0 I've:
remove R140, R141 - 10k
add R107, R115, R116 - 220R
I also add (they may not be essential):
C94 - 4u7 16v tant
Q20 - a143
On 1550-150x:
remove R78, R77 (Reverse Side)
add R37 (RS), R50 (RS), R38 - marked 221
add C82 - 4u7 16v tant
You can convert a P75 to P30/72. The only ones I've seen use the 1550 board and no KS.
I've converted one to p72 in the past.
Is that a US one you have?
I've also used a p29 1550 board and added KS, heated O2 and DOHC VTEC code.. for example.
The KS board itself has been documented elsewhere in terms of tuning the KS frequency - I
assume that's the R12 and R15 you refer to.
PostPosted: Thu May 13, 2004 2:55 am
He nice thanks i have to try it now.
Info i needed. will search for the r12 now and the tuning piece i haven't seen that
[%sig%]
PostPosted: Thu May 13, 2004 7:13 pm
I'm sure there are other scans of P30s on this phorum somewhere...
I was just looking at this ECU again:
http://www.pgmfi.org/phorum/download.ph ... 0front.jpg
And you can see that whilst the KS has been removed the resistors I mentioned haven't been
moved/removed - so if you want to remove the KS board you only need to worry about the ROM code.
This is presumably some sort of factory reprogramme job since the CPU doesn't seem to contain
a programme - it has no number stamp.
KS threads:
http://www.pgmfi.org/phorum/read.php?f=13&i=4872&t=4872
http://www.pgmfi.org/phorum/read.php?f=5&i=1785&t=1785
PostPosted: Thu Jul 21, 2005 4:45 am
I have to thank every one who helped me. My knock board in my p30-209 edm works. Tested yesterday. Probally i will test the knock logger tomorrow.
CJ
PostPosted: Fri Jul 22, 2005 3:27 am
i will put all my data i have here in to cvs.
PostPosted: Fri Jul 22, 2005 3:41 am
acongdon wrote:
Those link are dead, any inputs for this please ?
PostPosted: Fri Jul 22, 2005 9:28 am
Calv, you added KS in a P30-G00 EDM? How about the sensor? Where is located and what I need to do in mine to be able to use KS?
I want a KS too! :) Sometimes is a gooooood help! :)
PostPosted: Thu Feb 02, 2006 1:47 am
How about when removing knock sensor board? What should I do? I am going to use it in a SOHC VTEC engine - D15B
PostPosted: Thu Feb 02, 2006 7:31 pm
Don't bother removing it, you may want it later. Just disable it in the software and switch the jumpers over.
PostPosted: Tue Feb 28, 2006 3:13 pm
What is R107, R115, R116 - 220R?
220 ohm resistors or what?
Is it compulsory to add Q20?
