http://forum.pgmfi.org/
ecu sensors images added for TDC CKP cyl CYL
http://forum.pgmfi.org/viewtopic.php?f=54&t=17536
Page 1 of 1
Author:  chen [ Mon Feb 02, 2009 9:00 pm ]
Post subject:  ecu sensors images added for TDC CKP cyl CYL
http://wikitest.pgmfi.org/twiki/bin/vie ... tionSensor
http://wikitest.pgmfi.org/twiki/bin/vie ... nterSensor
:P :D
Author:  jagamasta [ Tue Feb 03, 2009 5:59 pm ]
Post subject:  Re: ecu sensors images added for TDC CKP cyl CYL
thanks, for that good & clear info!!
I had taken a search some time ago for images like that, but found nearly anything.
Has OBD0 VTEC (PW0, ...) the same working TDC, CKP & CYL-sensor like OBD0?
Author:  doc [ Tue Feb 03, 2009 6:38 pm ]
Servas! :)
Yes, they have the same signal pattern. You can exchange the ECU without changing the distributor.
If you want to exchange the reluctors between the distributor - i don't know, at least they look like the same.
Page 1 of 1 All times are UTC - 5 hours [ DST ]
https://www.phpbb.com/
