It is currently Sat Oct 04, 2025 5:20 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Sat May 28, 2005 5:58 pm
(NOTE: I know this doesn't really belong in chrome forum, but I figured it would be seen by more that are actually running 2.5bar map sensor.)
having problems on hooking up a motorola 2.5 bar map... I have signal to pin 1, ground to pin 2 and power to pin 3. Car runs like no map w/ uberdata (won't turn on) and won't rev w/ chrome (but idles fine). Checked with voltmeter and I have .4v w/ car @ 20in vac and .17v @ 0vac (engine off). I would think that there would be more voltage at 0vac then 20in vac. Any help appreciated...
PostPosted: Sat May 28, 2005 10:31 pm
i have it
but i run TurboEdit
maybe my info can help ya
0 volts = -30 InHg
1.75 volts = 0
4.5 volts = 21.5 PSI
heres is the wiring schematics
PostPosted: Sun Jun 05, 2005 2:29 pm
I have had the Motorola 2.5 bar running on both OBD0 and OBD1 without problems. Crome Boost Tools even has it listed as a "standard" MAP sensor now.
/Bindegal
PostPosted: Tue Jun 28, 2005 11:12 pm
Wait, so the only prongs on the 2.5 map sensor that need to be hooked up are 1, 2, and 3?
If so, that's easy enough. :D
PostPosted: Wed Jun 29, 2005 12:10 am
yes thats right, i installed mine yesterday, i just cut off 4,5,6. works great.
PostPosted: Wed Jun 29, 2005 1:22 pm
connecting the other pins on the 2.5 bar MAP will cause problems.
This should be wikied.
PostPosted: Wed Jun 29, 2005 6:57 pm
Dave...give me some help on how to Wiki better.
I have an entire instruction sheet with pictures and shit in Word that I could easily convert and wiki.
You have my number...
PostPosted: Wed Jun 29, 2005 7:27 pm
Chris, Wiki works pretty well with html from the one or two things ive wiki'd.
PostPosted: Thu Aug 04, 2005 2:41 pm
Figured I'd put this in here in case anyone else had a question about it...
I just took my stock map sensor off of my TB, and I was going to put the Motorola 2.5 MAP on. But they arent the same size. The screw holes dont line up, and on the stock map sensor, theres a little thing on the bottom that goes into the TB. The Motorola one doesnt have that, but it has the little vacuum nipple or something on the side of it.
Anyone have any idea how this is supposed to work? I can post pictures of the 2 if you guys dont understand what I'm talking about.
PostPosted: Thu Aug 04, 2005 2:46 pm
No one ever suggested the Motorola to be a drop-in replacement, because it isn´t.
Wire it up somewhere in the engine bay/firewall and route a vacuum hose to it (preferably one going directly to the manifold without all kinds of other stuff attached!)
/Bindegal
PostPosted: Thu Aug 04, 2005 2:51 pm
Oh ok.
So leave the stock MAP sensor in, but just dont hook anything up to it, and run a vacuum line to the Motorola MAP?
PostPosted: Thu Aug 04, 2005 3:41 pm
TurboGoKart wrote:
Oh ok.
yes
leave the stock one unhooked
wire the Motorola one inline to the 3 wires for the stock harness... but remember to have a plug in it, so u can unhook it and go back to the stock sensor if u need to.. and hook vacum to it
PostPosted: Thu Aug 04, 2005 4:04 pm
Here is the instruction sheet I used. If anyone needs it or wants to Wiki it...I cant figure it out :oops:
File comment: 2.5 Bar Motorola MAP Instructions
25BarMAP.doc [183.5 KiB]
Downloaded 1525 times
PostPosted: Thu Aug 04, 2005 11:05 pm
For shame! :wink: I got it Wikied for you: http://www.pgmfi.org/twiki/bin/view/Library/MapSensor
Thanks for the info!
PostPosted: Fri Aug 05, 2005 12:07 am
for all the dummies out there, since this is MAP sensor instalation 101 , i went ahead and added for them to cut the legs 4, 5 , 6 with a pair of dikes or something, so they dont have them just there and have touch Ground or something from the engine
