It is currently Thu Nov 06, 2025 7:19 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: 0-5v O2 Sensor Input
PostPosted: Thu Jul 16, 2009 11:13 am
mmmm...
hi guys..
I read the post and bump for this good idea.. but..
I have crome Pro and PLX AFR-WD 5volt blocked
We have another way to read the 20AFR without ecu modding?
If not..
how can i read it onto the ELD pinout on crome tuner?
sorry if the matter is spoked but i don't find the post...
PostPosted: Tue Apr 27, 2010 9:33 pm
can you install the stock o2 sensor back on the car if you do this mod
PostPosted: Tue Apr 27, 2010 10:55 pm
PGMFI Elf
Of course.
PostPosted: Sat May 22, 2010 7:57 pm
i know this post is old but im trying to this mod to my ecu , is it saying we r adding a 10uf cap to make it work or just add a jumper from the cap to r5 ???????? :roll:
PostPosted: Thu Sep 09, 2010 12:26 pm
PostPosted: Wed Feb 16, 2011 8:49 pm
would this mod be very beneficial or i can go without it?
PostPosted: Thu Feb 17, 2011 4:52 pm
If you limit the wideband output AFR readings to 0.06~3.8 volts, you dont need the mod.
The mod implies open-loop tunning/operation.
PostPosted: Thu Feb 17, 2011 8:28 pm
you get a way more accurate reading with 5 volts... for me, tuning is all about accuracy plus the lc-1 was made for 5v opperation..., any thing else is questionable as far as accuracy
PostPosted: Fri Jul 01, 2011 8:20 pm
For all the people who still ask how to do it:
Here's a little pic found in topic about 5v mod (made by acidz_z6) and edited it to be correct. The red line is the jumper mentioned above (it is suppose to be on the bottom side of PCB).
