It is currently Thu Nov 06, 2025 7:19 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sun Mar 11, 2007 9:13 pm
Cool I'll Try it out then.
 Post subject: Re: 0-5v O2 Sensor Input
PostPosted: Wed Jun 04, 2008 2:45 am
Am a bit confused so just let me know if my understanding of the mod is correct.
1) get a 10uF capacitor
2) remove R5 resistor
3) de-solder the right most hole below c70
4) run one leg of the capacitor through the de-soldered hole below c70 and the other leg through the right hole in R5 ( right hole would be the one towards the area where we put the 29c256 chip in)
5) this am confused about – the c3 pad.. the excess lead that comes out through the R5 hole goes where? What do we do with c3? Do we take it out or let it be there?
thanks
PostPosted: Wed Jun 04, 2008 6:46 am
You remove R5 as that is what feeds the input to the ADC circuit and limits the voltage down. C3 connects to the output of the circuit. The capacitor you are adding smooths out the voltage input to prevent small spikes. The negative lead goes to ground (Which is the hole you desolder that had nothing in it).. The positive lead you use to bridge the input (one of the pins to R5) and output (One of the pins to C3) together, bypassing the limiter circuit. Do it exactly as you see the line in the circuit. Only remove R5!
PostPosted: Wed Jun 04, 2008 9:04 am
k ..frm what i understand is
1) get the capacitor (10uF)
3) solder in one leg of the 10uF cap in the hole desoldered below c70
4) the other leg goes to R5 and is joined with c3 right hole
attached is a diagram ..
btw how would u know which one is positive leg and which one is ground of the capacitor?
thanks
PostPosted: Wed Jun 04, 2008 12:30 pm
anyone?
PostPosted: Wed Jun 04, 2008 8:23 pm
10 uf cap is normally radial.
It usually has plastic wrap around the canister and has - - - marks on the negative side..
also, if it is new cap, the negative lead is shorter than the positive.
PostPosted: Wed Jun 04, 2008 8:29 pm
it's difficult to show you jumper from top side..
the pictures in the beginning of this topic show it best that I can.
See this I added a little paint.. purple circle is the negative lead in the hole you solder to, the red lead is positive lead and jumpers from one pin to another. it must be exact holes shown or you could disable something else.. that's why I left the image zoomed out so you can see it in reference to everything else.
PostPosted: Wed Jun 04, 2008 9:58 pm
so basically its the same way u do like in the jpeg i posted. just that the positive lead goes in the right hole of R5 and then goes to the left side of C3 (instead of the right side as shown in my jpeg)
thanks
PostPosted: Thu Jul 17, 2008 8:23 pm
does it matter what voltage the cap is , as long as its a 10 uf ? what i mean is, can i use a 20 volt or 16 volt 10uf cap
PostPosted: Wed Jul 23, 2008 2:13 am
yes you can use the 16v or the 20 volts cap .. as long as they are 10uf..
i am using 20 volts 10uf cap myself
goodluck
PostPosted: Fri Sep 05, 2008 11:38 pm
Bump for a must-do modification! Just did it and it works great!
PostPosted: Sat Sep 06, 2008 7:41 am
The volts rating on the cap is the max volts you can apply without it blowing up in your face.. Always use something greater than the voltage you expect to see... in this case, about 14v. 16v is OK, 20v is better.
PostPosted: Thu Oct 09, 2008 8:07 pm
these directions still seem to be a bit vague....
its a pretty critical mod, i think directions should be a little more straight forward, and some larger, more detailed photos..
PostPosted: Fri Oct 10, 2008 6:08 pm
PGMFI Elf
It's not critical. There's 3 other actual 0-5v inputs that could be used instead.
PostPosted: Fri Oct 10, 2008 6:53 pm
exactly; like the ELD, right next to a solid power junction in the engine bay ;)
