It is currently Wed Apr 17, 2024 9:07 pm
 Post subject: SK-5151S & 1n4001?
PostPosted: Tue Oct 26, 2004 2:43 am
Does PGMFI have any of these for sale? I am trying to convert a P06, I'd like 5 or so of each...TIA
PostPosted: Tue Oct 26, 2004 8:14 am
1N4001 is a radioshack part.. You can get it virtually anywhere. Standard diode
PostPosted: Tue Oct 26, 2004 12:59 pm
Thanks, so all I will need to locate then is the 5151's. i just figured that I would try to purchase from PGMFI in an attempt to donate some to the cause...
PostPosted: Tue Oct 26, 2004 1:50 pm
We've talked about getting an order of 5151s, but it's kinda expensive. I'm sure there will be plenty of interest if we can get it together...
PostPosted: Tue Oct 26, 2004 2:24 pm
Sounds good. I will be interested, if there is a new order that gets placed I'll probably even buy 20 or 30 just to ensure that I have some ........
PostPosted: Tue Oct 26, 2004 3:45 pm
Depending upon cost, I'd be in for 10 or so. Course, would this be for the equivalent that Digikey has? How many would we need for a better price? 50?
PostPosted: Tue Oct 26, 2004 4:04 pm
500 minimum for the true-blue Allegro/Sanken SI-5151SG (which replaced the Sanken SK-5151 used in our ECUs)
PostPosted: Thu Oct 28, 2004 2:05 pm
If you're looking for SK-5151, just use a IR6220..
Please see viewtopic.php?t=181&highlight=sk5151 first for specific install instructions.. :)
 Post subject: sk 5151 or equiv
PostPosted: Tue Nov 30, 2004 4:41 pm
I have an account with Allegro if there is INTREST in 5151's let me know?
Otherwise I have IR-6220 with the pin configuration that matches the 5050 - 5151 as a direct drop in.
Joshua Villasenor@yahoo.com
:D :D :roll: :roll: :D :D
 Post subject: Re: sk 5151 or equiv
PostPosted: Mon May 16, 2011 9:58 pm
I know this is an old old old topic but i am INTERESTED in the 5151's.
What's the break down on the "amount purchase" and "price" on that?
I tried searching part # IR-6220 but nothing came up on Digikey or Allegro.
Let me know...
Thanks!
 Post subject: Re: SK-5151S & 1n4001?
PostPosted: Tue May 17, 2011 6:30 am
Most members in this thread no longer have active accounts, so not likely to get a response, plus since then, they have discountinued 5151s I believe, so you will have to order them from someone who has a stock. I believe Xenocron and Moates do, Smooth1 (hrtuning) might have them as well.
PostPosted: Thu May 26, 2011 10:35 pm
I have over 700 hundred sk5151s. If interested contact me via message
