pgmfi.org http://forum.pgmfi.org/ |
SK-5151S & 1n4001? http://forum.pgmfi.org/viewtopic.php?f=49&t=3731 |
Page 1 of 1 |
Author: | Guest [ Tue Oct 26, 2004 2:43 am ] |
Post subject: | SK-5151S & 1n4001? |
Does PGMFI have any of these for sale? I am trying to convert a P06, I'd like 5 or so of each...TIA |
Author: | Ltdannear [ Tue Oct 26, 2004 8:14 am ] |
Post subject: | |
1N4001 is a radioshack part.. You can get it virtually anywhere. Standard diode |
Author: | sandoz [ Tue Oct 26, 2004 12:59 pm ] |
Post subject: | |
Thanks, so all I will need to locate then is the 5151's. i just figured that I would try to purchase from PGMFI in an attempt to donate some to the cause... |
Author: | blundar [ Tue Oct 26, 2004 1:50 pm ] |
Post subject: | |
We've talked about getting an order of 5151s, but it's kinda expensive. I'm sure there will be plenty of interest if we can get it together... |
Author: | sandoz [ Tue Oct 26, 2004 2:24 pm ] |
Post subject: | |
Sounds good. I will be interested, if there is a new order that gets placed I'll probably even buy 20 or 30 just to ensure that I have some ........ |
Author: | Kabuki [ Tue Oct 26, 2004 3:45 pm ] |
Post subject: | |
Depending upon cost, I'd be in for 10 or so. Course, would this be for the equivalent that Digikey has? How many would we need for a better price? 50? |
Author: | blundar [ Tue Oct 26, 2004 4:04 pm ] |
Post subject: | |
500 minimum for the true-blue Allegro/Sanken SI-5151SG (which replaced the Sanken SK-5151 used in our ECUs) |
Author: | Gotz2B16 [ Thu Oct 28, 2004 2:05 pm ] |
Post subject: | |
If you're looking for SK-5151, just use a IR6220.. Please see viewtopic.php?t=181&highlight=sk5151 first for specific install instructions.. |
Author: | joshuavillasenor [ Tue Nov 30, 2004 4:41 pm ] |
Post subject: | sk 5151 or equiv |
I have an account with Allegro if there is INTREST in 5151's let me know? Otherwise I have IR-6220 with the pin configuration that matches the 5050 - 5151 as a direct drop in. Joshua Villasenor@yahoo.com |
Author: | West Coast [ Mon May 16, 2011 9:58 pm ] |
Post subject: | Re: sk 5151 or equiv |
joshuavillasenor wrote: I have an account with Allegro if there is INTREST in 5151's let me know? Otherwise I have IR-6220 with the pin configuration that matches the 5050 - 5151 as a direct drop in. Joshua Villasenor@yahoo.com I know this is an old old old topic but i am INTERESTED in the 5151's. What's the break down on the "amount purchase" and "price" on that? I tried searching part # IR-6220 but nothing came up on Digikey or Allegro. Let me know... Thanks! |
Author: | inspector01 [ Tue May 17, 2011 6:30 am ] |
Post subject: | Re: SK-5151S & 1n4001? |
Most members in this thread no longer have active accounts, so not likely to get a response, plus since then, they have discountinued 5151s I believe, so you will have to order them from someone who has a stock. I believe Xenocron and Moates do, Smooth1 (hrtuning) might have them as well. |
Author: | sicknastyb17 [ Thu May 26, 2011 10:35 pm ] |
I have over 700 hundred sk5151s. If interested contact me via message |
Page 1 of 1 | All times are UTC - 5 hours [ DST ] |
Powered by phpBB® Forum Software © phpBB Group https://www.phpbb.com/ |
