It is currently Sat Mar 23, 2019 4:58 am
 Post subject: Whatever happened to...
PostPosted: Wed Aug 25, 2004 4:02 pm
PGMFI Elf
...The Engine Sim project....
PostPosted: Wed Aug 25, 2004 4:17 pm
I was just wondering that myself. I saw it in the Wiki this morning but couldnt find it on the new forum.
PostPosted: Wed Aug 25, 2004 4:54 pm
PGMFI Elf
I'm dying here now that I've sold my hatch... I'm definitely going to have to do something...
PostPosted: Wed Aug 25, 2004 4:56 pm
everything is in CVS ... just haven't had time to finish it
PostPosted: Wed Aug 25, 2004 5:47 pm
PGMFI Elf
 Post subject: IACV?
PostPosted: Fri May 27, 2005 12:16 pm
Did you guy's ever find a working solution to your IACV issue?
PostPosted: Wed Jun 01, 2005 3:49 pm
no.
PostPosted: Wed Jun 01, 2005 7:35 pm
Not sure exactly what you guy's are using for that, but I came up with an idea (depending on your current solution, no extra parts may be needed). From my understanding, the IACV is a PWM like device and the ecu measures that signal to find out if it is correct. The idea I had is to record the various output values of the IACV (using scope or other device) during various modes of operation. Then, if the engine simulator uses a microprocessor, run the ECU pins for the IACV to the mcu on I/O pins. then use software/PWM on the mcu to drive the ecu pin(s) appropriately.
PostPosted: Wed Aug 17, 2005 5:48 am
Here is some linkage:
http://forum.pgmfi.org/viewtopic.php?t=240
http://forum.pgmfi.org/viewtopic.php?t=193
I dont really consider the IACV a problem though, sure it would be nice to have a replacement, instead of a hunk of metal on the bench, but just pick up a spare from a breakers and use that. Someday i will draw out the IACV output stage and that'll give an idea on how its obtaining feedback.
Going to build my own sim at some point though, as its annoying/impossible to test certain things in real life on an engine. Will post full details on it when it happens, but i cant say when.
Is anyone still interested in working on something like this?
PostPosted: Wed Aug 17, 2005 11:24 am
I am for sure. I have a AS in Electronic Engineering, so I should be able to help out. I am learning the asm stuff and wan't to try some things... and don't want to mess up my daily driver. I guess I should dig into the cvs and get up to speed.
PostPosted: Wed Aug 17, 2005 12:35 pm
FYI, all the old engine sim files are part of the CVS tree.
