HEllo, I get a kit for mount a turbo, T25, in my civic hatch 5ยช D16Z6,
I have the ecu chiped for NA setup, fuel map regulated according my wideband PLX250 and all ok
But I have questions before I goes to mount the turbo,,
Which fuel map I can use for the engine first start???, to avoid detonation, I think first go too rich and slowly, with the PLX, correcting the fuel map lowing fuel... but How calculate the fuel to first setup knowing the psi is about 8, I expect about 200hp, stock internals, stock injectors (but with wallbro pump), fuel 98 octanes... ??
And the second question, I dont understand ignition maps, how I can adjust this map to avoid detonation? I think I have to advance the ignition, but how much?? how I can monitorize this advancing and know if the adjust is correct or is a bad adjust?
THanks a lot really & sorry for my english.
