It is currently Sat Oct 04, 2025 5:15 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
PostPosted: Sun Nov 27, 2005 7:33 pm
is there any way i can retain my cable speed sensor but have vtec still engaging...i will be using crome or neptune depend's on which tuner i am going to and i want to see how this will effect me with this problem...does these program's use something else to engage vtec like is it in the map already? also will vtec pop all the time or only at a certain engine temp as it should...thank you guy's
PostPosted: Sun Nov 27, 2005 10:21 pm
as long as you keep your OBD0 cluster, you'll be fine. The speedo in USDM OBD0 cars is in the guage cluster, and is cable driven from the transmission. If your speedo worked when the car was OBD0, it will work with it OBD1.
As for vtec engaging - Crome uses the stock code, so vtec engaging will be like stock and will be affected by everything the stock code is affected by.
And please READ. Try to ask questions in the assistance forums NOT the development forums. There are no exceptions to this because you'll find that finding things here is hard enough without repetitive questions crowding threads describing work in progress. :evil: :)
Users browsing this forum: No registered users and 26 guests
