It is currently Fri Apr 19, 2019 5:00 pm
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
Are you horny?
All the time. 52%  52%  [ 589 ]
Right now, yes. 7%  7%  [ 83 ]
Right now, no. 17%  17%  [ 190 ]
Newbie here... What is horny? 13%  13%  [ 142 ]
I'm like a bad ECU -- always on limp mode. 11%  11%  [ 124 ]
Total votes : 1128
PostPosted: Mon Mar 12, 2012 3:33 pm
HHEEEEELLLPPPPPP!!!! MMEEEEEEE!!!!!!! :x :mrgreen:
PostPosted: Sun Apr 08, 2012 11:36 am
Hi. I've got a boosted b16 hatch that I blew up a couple of months ago, but at the moment I am rebuilding a Gsr block, with a b16 head on it. It is going to be a fully built motor, and I plan to use eCtune for my tuning software to tune my setup. Has anybody ever experienced with eCtune before ?
PostPosted: Sun Apr 29, 2012 10:50 am
Hi,
Bit old to be horny :wink: ...been racing,building and playing with Hondas since 70's and only now looking at using and tuning Mr Hondas own units....
Have been running Autronic on own cars and various on customers so have a few units in the cupboard to play with
Cheers
Lynds
PostPosted: Tue Jul 03, 2012 6:17 pm
hi!
can someone expalin me what does high and low fuel/ignition maps mean?
is it only for vtec engines when the cam profile changes , and for a regular engines i just need to tune the low fuel/ignition maps?
PostPosted: Tue Jul 03, 2012 9:31 pm
Low cam is before the set vtec engagement point. High cam is vtec engaged when mid lifters are locked. So yes nonvtec motors will not use the high cam tables
 Post subject: Crome Newbie..
PostPosted: Sun Sep 09, 2012 8:39 pm
Ok good day everyone. Im trying to get this winodws xp laptop set up with either crome or ectune to run my P0 with Demon installed. after finding out that the neptune wont run the thing until its purchase... the only options I heard of was crome... I downlaoded 1..5 and it crashes right after loading it flashes a graph on screen right efore failing.. now is this the right freeware I should e tryin to get this thing atleast running?
PostPosted: Mon Sep 10, 2012 7:35 am
HI all the newbies. I'm from spain, i hope to learn a little bit (english and ecu tuning XD)
PostPosted: Thu Sep 13, 2012 5:38 pm
Hello to everybody! :D try to find more interest for New ECU types! Thx for any help people!
regards form russia!
PostPosted: Thu May 30, 2013 11:40 am
hi..5555
PostPosted: Fri Aug 16, 2013 1:36 am
3========D------- hehehe
PostPosted: Mon Oct 07, 2013 5:22 pm
vtec just kicked in yo
PostPosted: Tue Nov 26, 2013 9:09 am
Yes Horny Horny Here lol!
Q? How can you fine tune a automatic h22 with crome, using a rechip p06 manual ecu?
My problem is: Delayed Shifting when your in Drive and sometimes it stays in 4th gear and dosent downshift when i stop,
Then when i put the stock matic ecu it runs ok, so meaning there is no problem with the tranny just the ecu dosent sync with the tranny is there a way to fix this?
Reason: Why the H3LL tune a matic! well just want to experiment if it is possible to make a matic run better then its stock factory tune.
Hope to get some ideas Thanks2 in advance
PostPosted: Tue Dec 16, 2014 11:21 pm
whats up cuzo just tryna het this z6 in the ef goin
PostPosted: Sun May 29, 2016 6:47 am
Hello
I am a newby with an FK1 MY2010 CIVIC in which i managed to swap the stock engine (1.3) with an LEA1 coming from a CRZ (1.5) with some slight mods (IMA out, oil pan, engine mounts).
The engine runs ok with my stock 1.3 ECU and the A/F is ok in all conditions (open/closed) but the LEA1 and all hybrids have increased advance compared to normal engines. Ignition advance inLEA1 is 10 deg in idle and in L15/L13 is 0-2 deg.
So i am thinking if i can carry the CRZ stock maps in my ECU.
I am looking for the proper read/flash tool since the Keihin ECUs are not supported from most of the tools like MAG pro, KWP2000 etc
Any ideas what to buy in order to read the stock maps from a CRZ and flash them in my ECU? :D
PostPosted: Sat Aug 06, 2016 5:18 am
Hi
I'm new and I have a problem with Vtec engine 2.2 japan and ECU P28, Driver runs Vtec but after reducing the power does not switch to the mode of economic driving .Best not to know English, and I apologize for any mistakes
Users browsing this forum: No registered users and 20 guests
