I keep getting the message:
"Sector number 0 can't be programmed successfully! Please check your hardware and the flash eprom!"
at the end of the burning process. So I did the hardware test, and everything went fine until the 2nd voltage test (3-5v) on #16. It got nothing. Same thing on the next voltage test (10-13v?) and got nothing on #16 again. #1 and #3 (the other two in the test) tested out fine. On the voltmeter I'm using DCV 20, is this the correct setting?
So my guess is that there's a bad connection somewhere or a part not installed correctly. This is my very first small electronics project with diodes and transistors and what not, so I'm very new and do not have much knowledge, pulling my way through by message boards and bugging J.Davis. Are the transistors suppossed to be directional? Anyways, here's a pic of the board if anyone can compare and help me out
Thanks! -Sean
http://www.norcalcrx.org/spoon2/pics/burner.jpg
EDIT: by the way, after the test it said to especially check R1-R4 and R6
Post Edited (10-25-03 01:00)
