It is currently Sun May 12, 2024 4:46 pm
 Post subject: P06 voltage issue
PostPosted: Tue Aug 10, 2021 5:55 am
Hi guys, I'm new to this forum, all the way from Johannesburg South Africa.
I seem to have an issue with my US imported P06 ECU that was converted to P28, and running a Demon v1.2 board (ECU was imported many years ago already chipped, and C14 changed).
The C24 cap leaked onto the board, which made me change all the caps except, however I am now reading a higher batt voltage on the Neptune datalog, i.e. instead of 12v or ~14v at idle, it reads 14-15v and 16-17v at idle. Tracks have been cleaned and tested for continuity, all seem good.
What could possibly cause this?
Battery is good, alternator is good. Checked to confirm.
Batt voltage = 12v going in to ECU.
Datalog voltage = higher than batt in voltage.
Are there any circuits on the board that may need to be checked, IC's or other components that may need to be changed/repaired?
Thank you
