hugo19 wrote:
Hello guys !
I´m attempting to run a 99 HRV with a P28 on a conversion Harness... well, it runs like crap ...
I´ve burned a chip with a P28 slight modified base map (CROME) and some checks eliminated but still not good (stalls when you press gas pedal, after 3000 rpm goes fine, engine light on).
i´ve been searching all around for the HRV base map and got no luck... the ROM supposed to be 894. Then, i tried roms from look alike engines... still no luck
Can someone show me the way to go , please ?
yes, i´m a newbie !!!
thanks
There is no basemap for that, you have to custom tune it.
