It is currently Sun Jan 24, 2021 11:06 am
 Post subject: MB P1K - P1J
PostPosted: Thu Aug 08, 2019 5:28 pm
I have a d16b2 from an auto MB, it has a P1k e63 ecu and an LED distributor.
I'm fitting the engine into another manual MB that currently has a d14z4, a p1j e15 ecu and a normal dizzy.
Neither of these ecus can be chipped
If I keep the distributor from the 1.4, could I use the 1.4 ecu to run the 1.6?
I presume not.. so the next issue is, finding the pinout for the p1je15 as I've read the A plug, iacv and injectors are different...
I have a z6 intake manifold but can use the tb from the d16 retaining the iacv. This could he an option if one of the above ecus can be used.
I'll be swapping in a p28 once I have the rest of the turbo parts. But for now I just want it to run.
Any help would be appreciated.
Thanks.
