It is currently Fri Jan 15, 2021 3:54 pm
 Post subject: JDM ECU AT for RTP?
PostPosted: Thu May 30, 2019 5:30 am
I have a 1999 Acura Integra GS (OBD2) with a fully built Frankenstein LS/VTEC with a JDM SIR-G Automatic Transmission running on a chipped (basemap) JDM P30 AT ECU (OBD1) provided by Xenocron. My goal was to run Moates Demon 1. Found out it's no longer in production. I don't know what other options I have for RTP.
I thought about Hondata since I have a separate TCM. Not sure if it will control the lockup solenoids, adjust the shift point, etc. I can't find any wire diagram schematics online to understand on how the whole thing works with the ECU and TCM.
Should I say screw it and get the Moates Ostrich 2.0 and Hulog? Then again don't know if this will work on the JDM A/T ECU.
 Post subject: Re: JDM ECU AT for RTP?
PostPosted: Tue Jun 04, 2019 4:23 pm
PGMFI Elf
HAMotorsports.com is said to have some AT compatible options available.
Users browsing this forum: Bing [Bot] and 21 guests
