It is currently Mon Nov 24, 2025 10:27 pm
PostPosted: Wed Aug 24, 2016 12:29 pm
Hi, I have a SST27sf512 but I can“t to copy my chip, I push "read from chip" and only appear "FFFFFFFFFFFFFFFFFFFFF"
I use the mini pro programmer
PostPosted: Wed Aug 24, 2016 12:47 pm
PGMFI Elf
Did you check the second half of the data?
PostPosted: Wed Aug 24, 2016 1:02 pm
I dont know use the program, I only put de chip, select the 27sf512 in the program, and push "read from chip"
I do that 3 steps. are any more?
PostPosted: Thu Aug 25, 2016 10:22 am
PGMFI Elf
There's a scrollbar on the right side. Scroll down to the second half of the data and see if it's empty.
PostPosted: Sat Sep 10, 2016 2:32 pm
Just to confirm, check your SST chip, some time it fake chip write SST27SF512 Windbond. If yes you should try select W27C512. And like smooth1 said. check at x8000 line for second half data.
Or you can setup select range x00000000 to 0000FFFF to x00008000 to 0000FFFF
Users browsing this forum: No registered users and 17 guests
