Hi,
Thank you for answering this fast.
I think there are some other ways to remove the immo.. for example, this tuto:
http://www.ozhonda.com/forum/archive/in ... 48704.htmlExplains how to remove it from the following ECU versions:
P73 from DC2R
P30 from 97 CRX
P2T from EK4 ecu ( thanks to Phuong1987 )
P72 from DC2 Integra ( thanks to VTec1987 )
P2P from EK VTi ( thanks to VTec1987 )
I'm not sure the P1G applies to this procedure, and that's why I'm asking.
So if anybody has a link to something similar or a document to share, please do
If it's the same ECU generation, the board should be very similar if not identical, then you can try to apply one of these instructions that seems to fit best.
