Hey all, first post so bare with me.
I've been reading up on what I need to run crome and I think I have a basic idea, but would like to run it by all of you before I start buying parts.
My engine setup:
GSR rods/crank/head/cams/block
USDM Type R pistons
Supertech dual valve springs
Blox high compression valves
Blox IM
Skunk2 throttle body
Exedy clutch and lightweight flywheel
Straightpiped exhaust
some other odds and ends that I'm probably forgetting about
I plan on adding Skunk2 Pro1+ cams in the future but want to get this going first.
As for the ecu, I have a 98 GSR ecu (obd2a) that I used to run the engine with when it was stock (then the body got totalled so i built the engine to what i stated above and now its in a 94 civic coup) i also have an obd1 P06 that came with the shell i swapped the engine into
So now for my real question, from what I gather I'll need an obd1 ecu to run crome, but the p06 is non vtec so here's what i'm thinking
P06 ecu
vtec conversion kit
ZIF socket
Ostrich 2.0
crome pro
Wideband O2
Any suggestions on what O2 to get for realtime datalogging on crome? Anything else I missed (like wires, chips etc?)
Thanks in advance for your help! I'm really trying to get everything going so I can start contributing to this forum
