It is currently Sat May 18, 2024 9:35 pm
PostPosted: Thu Dec 12, 2013 2:06 pm
Hey guys I'm new to the forum and have had an odd problem since I first started tuning my car. I've been running my friends p30 map with dsm 450s for 10psi on a b16. We both have the same setup, same turbo, and stock map sensors, the only difference is I have skunk2 stage 1 cams. The car runs great in low cam, even when you get into boost, but once you cross into high cam it falls on its face, goes ridiculously rich, and will run like crap all over the board until you turn the car off and then back on. Also, I have my o2 sensors deleted yet, I'm getting an obd1 engine code for them. What is going on. :?:
PostPosted: Fri Jan 03, 2014 11:25 pm
either your rom is corrupt or it's not actually running the chip at all. first, copy your tables to a new base, then set your launch control to something predictable and make sure it's operating from the rom.
additionally the skunk2 cams are significantly different than stock, it's going to run like balls until you tune it, assuming you don't fry the engine first.
Users browsing this forum: Bing [Bot] and 24 guests
