Hey guys I'm new to the forum and have had an odd problem since I first started tuning my car. I've been running my friends p30 map with dsm 450s for 10psi on a b16. We both have the same setup, same turbo, and stock map sensors, the only difference is I have skunk2 stage 1 cams. The car runs great in low cam, even when you get into boost, but once you cross into high cam it falls on its face, goes ridiculously rich, and will run like crap all over the board until you turn the car off and then back on. Also, I have my o2 sensors deleted yet, I'm getting an obd1 engine code for them. What is going on.
