It is currently Fri Apr 19, 2024 8:49 am
PostPosted: Wed Oct 30, 2013 8:58 pm
Hey guys, new to the forum. I drive an 89 crx si. I love this car and just like to learn more about it so I stumbled across this website along with turboedit the other day and decided to check it out. I have downloaded TE 3.2.2 on Windows 8 and can open NG_63(5Q) and have downloaded the extratables file; but when I try to install the file in the plugin manager I get the following codes: Regsvr32, extratables was loaded but the call to Dllregistersever failed with error code 0x80004005 and ActiveX component cant create object.
From searching I found this: I`m not an expert on this but from my 2 weeks struggle with turboedit and ecucontrol, if you get a regserv error that means that you haven`t registered the resource files of ecucontrol or turboedit.Download the resource files of ecucontrol AND turboedit and put then in system32.Then you should run the regsrv command on CMD window (don`t remember the command exactly, just search on pgmfi for it) and all should be fine!
I have tried uninstalling and reinstalling both the extratables setup.exe and the ng_63(4) with no success.
Can someone please point me in the right direction. Thanks in advance.
PostPosted: Thu Nov 28, 2013 12:07 am
I had the same problem on vista. After trying several things and many peoples advice, the solution was to use my other computer with winxp. No further problems.
Users browsing this forum: No registered users and 26 guests
