It is currently Thu Oct 30, 2025 3:26 am
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
PostPosted: Fri Jan 30, 2015 2:16 am
got my self a chipped P72 and am trying to find if there is a plug in or something for ignition cut rev limiter? went for a bit of a look on the tune with crome website and on the feature under plugins under ROM enhancements it says its a default feature but haven't found anything yet. so any links or info would be helpful
PostPosted: Fri Jan 30, 2015 7:45 am
If you send me the binary file of the program memory of your P72, I can change the ignition cut rev limiter at your request.
PostPosted: Fri Jan 30, 2015 10:04 pm
That'd be great. will do. just wondering if it is something i can do myself? and if not is it just the normal rev limiter rpm i change to change the ignition cut rpm?
PostPosted: Fri Jan 30, 2015 10:05 pm
also how would i go about sending the bin file to you?
PostPosted: Sat Jan 31, 2015 4:59 am
:arrow: d.pelegri@orange.fr
after, I would indicate the addresses to be changed for the rev limit.
PostPosted: Sun Feb 01, 2015 1:41 am
Thanks. Sent the roms to you
PostPosted: Sun Feb 01, 2015 3:51 pm
Received. I work on it.
PostPosted: Wed Feb 04, 2015 6:38 am
Werd_103, I have send email to you.
"269stock.bin" (no change) => Rev Limiter :
Fuel : Cut at 8100 rpm and Reset at 7900 rpm
Ignition : no actif
"269stock_IngRevCut.bin" (add Ign Rev Limiter) => Rev Limiter :
Ignition : Cut at 8100 rpm and Reset at 7900 rpm
If "269stock_IngRevCut.bin" is ok, I make same change in your second bin file.
Didier
PostPosted: Wed Feb 04, 2015 4:27 pm
Your email :
Quote:
Thanks heaps. Is there an easy way to describe what you did? Is there anything I cant edit without disturbing the ignition cut? And what is the ignition cut limiter set at?
Is there an easy way to describe what you did ? :arrow:
Here is the summary.
Init FlagRevLimiter :
if FlagRevLimiter = False then ValueRevLimiter = 8100 rpm else ValueRevLimiter = 7900 rpm
if Engine_RPM<ValueReLimiter then FlagRevLimiter = False else FlagRevLimiter = True
In Fuel Injection routine :
if FlagRevLimiter = False then Fuel Injection = Run else Fuel Injection = Stop
In Ignition routine (I have add) :
if FlagRevLimiter = False then Ignition = Run else Ignition = Stop
Is there anything I cant edit without disturbing the ignition cut ? :arrow: It depends on your expertise.
What is the ignition cut limiter set at ? :arrow: I gave the indication in my post above.
PostPosted: Wed Feb 04, 2015 8:19 pm
PostPosted: Wed Feb 04, 2015 9:11 pm
thanks heaps dip. ill try it out asap
PostPosted: Wed Feb 04, 2015 9:23 pm
In my last picture :
AL is not "= Image Engine Rpm" but "= Image Ignition Advance".
Sorry.
PostPosted: Sun Feb 22, 2015 4:34 pm
You tested :?:
PostPosted: Wed Mar 18, 2015 2:44 am
hey is this still alive ??? i really would like to see a plugin it would be nice thanks
PostPosted: Wed Mar 18, 2015 3:07 am
No news of werd_103
Users browsing this forum: Google [Bot] and 32 guests
