It is currently Tue Apr 16, 2024 4:13 am
 Post subject: am i right or wrong
PostPosted: Tue Jan 08, 2013 4:26 pm
ok i have been doing lots reading in the library section about remaping and i want to know if i am right or wrong or close here it goes
i think you have to burn a base map to the a blank chip put it in to a socketed ecu and then you can use the cars diagnostic socket to connect it to a laptop using ECUControl or something similar to adjust the fuel and ignition maps. i am very new to this i think i might be wrong there's lot's of info it's easy to get confused lol
sorry if this makes no sense
 Post subject: Re: am i right or wrong
PostPosted: Fri Jan 11, 2013 3:49 am
You're wrong. More info on the setup and plans would help us help you.
You need a chip or emulator in the ecu that is programmed with the external rom you're looking to run. You'll datalog through the ecu to see what the engine is doing, then make changes to the rom and put them in the ecu and repeat.
PostPosted: Sun Jan 13, 2013 9:26 am
hello sorry for late reply most of forums im on sends my an email to say i got a reply any way
my plans are for crx or civic eg not sure yet i want to run skunk2 stage2 cams aftermarket valves and spring Retainers port & polish ITB'S and not sure for bottem end maybe b16b pistons must point out im no expert lol
PostPosted: Mon Jan 14, 2013 12:52 pm
I don't really care about that stuff, more the ecu end of things. It will depend on what ecu/software/hardware you go with, but the general premise is the same as what I said in other post.
PostPosted: Mon Jan 14, 2013 4:23 pm
hello i think i am going to go back to the library section and do more reading as i have no idea what your talking about lol
sorry if this is annoying you i am still very new to this but want to learn. this is only for personnel use only
PostPosted: Tue Jan 15, 2013 8:11 am
Keep reading, start with the wiki and progress of a noob threads, and a few of the guides that have been written up.
Users browsing this forum: Google [Bot] and 12 guests
