It is currently Thu Oct 30, 2025 8:54 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Top853 programmer
PostPosted: Sat Aug 18, 2012 12:08 am
Hi everyone, anyone got the " TopWin " program to burn the chip with the top853? i tried the chinese website but it doesnt work. So if anyone have a copy of the install it would be great! Thank you
 Post subject: Re: Top853 programmer
PostPosted: Sat Aug 18, 2012 6:10 am
I have, I use and it works perfectly.
Send me your email and I will send you a copy of the software CD.
PostPosted: Sat Aug 18, 2012 7:23 am
email is smart_parts1@hotmail.com Thank you!
PostPosted: Sat Aug 18, 2012 7:50 am
email sent
PostPosted: Sat Aug 18, 2012 8:38 am
http://www.topwin6.com/Soft.html
http://www.topwin6.com/pdf/TopWin6Manual_e.pdf
PostPosted: Sat Aug 18, 2012 4:27 pm
I also have one and love it, just remember to my knowledge it still does not work with windows 7. Unless they have released a update
PostPosted: Sat Aug 18, 2012 4:35 pm
For information : I use with Windows XP Pro service pack 3
PostPosted: Sat Aug 18, 2012 9:20 pm
Me also
PostPosted: Fri Aug 24, 2012 8:02 pm
I am looking at buying the same burner. I have used the moates burn 2 and it worked fine but I am buying my own and seen good stuff on the Top. I have windows 7. Does that make the TOP out of the question for me or is here a way i can get by? Can i just use the burn process thats on CROME?
PostPosted: Fri Aug 24, 2012 8:14 pm
The top 853 will NOT work with windows7. I am not sure if top has a different burner that works with windows7, but as of now the latest software version for the 853 does not work on windows7. Cromes built in burn interface only works with the moates burn1 and burn2.
PostPosted: Fri Aug 24, 2012 10:33 pm
Well damn, guess I need to keep saving. Thanks for the info man.
PostPosted: Wed Sep 05, 2012 3:20 am
I burn with a top853, you guys are correct that they have not updated it to work with windows 7 yet. But i did find a fix for it. Plan on posting it up here for you guys as well.
For now ill just post a link to it untill i have time to transfer it. I hope this is ok mods.
http://hondaville.com/honda/threads/600-Burning-with-top853-and-windows-7
PostPosted: Thu May 02, 2013 4:38 pm
Are top 853 programmer support 27c256 that used 12v to program? i read the manual show it only support 5vdc devices?
PostPosted: Thu May 02, 2013 10:32 pm
Do you have a complete part number? I have programmed sst27sf256 and st27c256 with 853 top. What brand 256 are you talking about? and is it uv or electric erase?
PostPosted: Mon May 06, 2013 4:45 am
Im using mostly MBM27256-25 chip with uv erase type, and Fake China SST27SF512-70-PG, this chip cannot used with moates burn2 programmer. Only success and done programming burn into chip with Willem programmer.
Users browsing this forum: Google [Bot] and 14 guests
