It is currently Tue Apr 16, 2024 1:39 am
 Post subject: PG7 ECM
PostPosted: Wed Feb 01, 2012 11:48 pm
Looked through the list on wiki test and didn't see PG7 listed:
What car did this ECU come from?
PG6 88-89 Integra (all makes)
PM5 88-91 Civic/CRX DX
PM6 88-91 Civic/CRX SOHC Si
PM7 89-91 DOHC ZC (JDM 'EF' ECU)
PM8 88-91 CRX HF
PR2 89-91 ZC (Euro)
PR3 89-91 JDM B16A EF8/9
PR3 -J00 or J51 92 JDM Integra B16A EF8/9
PW0 89-91 JDM B16A EF8/9 DA6-XSi
PR4 90-91 Integra LS/GS
PS9 88-91 4 door Civic EX Auto
P05 92-95 OBD-1 Civic CX
P06 92-95 OBD-1 Civic DX
P07 92-95 OBD-1 Civic VX
P08 92-95 OBD-1 Civic D15 JDM
P0A 94-95 OBD-1 Accord EX
P13 93-95 OBD-1 Prelude Vtec
P14 93-95 OBD-1 Prelude Si (non Vtec)
P27 92-95 OBD-1 EG JDM Civic 1600 sohc
P28 92-95 OBD-1 Civic Si/Ex
P30 92-95 OBD-1 Del Sol? DOHC Vtec Si/EG Si R?
P54-G31 1997 Honda Accord 1.8 LS
P61 92-93 OBD-1 Integra GSR
P72 94-95 OBD-1 Integra GSR
P72 96-00 OBD-2 Integra GSR
P73 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75 92-95 OBD-1 Integra LS/GS
P75 96-00 OBD-2 Integra LS/GS
P2N 96+ OBD-2 Civic HX Coupe
P2P 96+ OBD-2 Civic EX Coupe
P2E 96+ OBD-2 Civic DX Coupe
P2M 96+ OBD-2 NZ Civic SOHC VTEC
P2T 99+ OBD-? Civic Si Coupe
P5P 97-00 OBD-2 Prelude Type-S (JDM ECU)
PBA 97+ US Acura 1.6EL
PCT 98+ JDM ITR / CTR
PCX 99+ OBD-? S2000
It came with a D16A8 I purchased through Craig's List. the guy I bought the engine/trans from said it was faster than his 99 Si. I haven't driven it yet (still sitting on the floor in the garage) I needed the trans more than the engine. Has anyone information on this on? I have peeked inside to find it does not have an external EPROM. And it does not appear to have been modified ( everything looks stock and factory clean). The research I have done shows this engine came from a Rover model available in Euro. Any info would be appreciated. Not exactly sure where this A8 will end up... I have a few projects in mind.
 Post subject: Re: PG7 ECM
PostPosted: Thu Feb 02, 2012 9:02 am
Your post is incorrect. The pg7 ecu came in the 86-89 integra. d16a1 motor. Be careful for the 86-87 ecus are vaccum advance. The 88-89 ecus are electronic advance. 88-89 ecus have a external eeprom but I am not sure about the 86-87 ecus.
PostPosted: Sat Feb 04, 2012 11:00 am
the pg7 is a pretty decent option for the zc motor and other variants of the zc
the pg7 has a higher rev limiter and no speed governor iirc. the tables are a lot closer for the zc but you will be running a little rich ...which per say isn't all that bad.
However...chipping the pg7 can be a pita as it uses the larger eproms. you'd be better off chipping a pm6 and installing the appropriate bin.
X2 on the vacuum advance 86/87 variant!
PostPosted: Sun Feb 05, 2012 7:53 pm
From my own experience, a PG7 will run worse on a DOHC D than a stock 90-91 PM6, but it has the proper 7,800RPM rev limit.
The best solution, IMO, is to run a stock EDM PM7 bin in a chipped PM6. This will be one of the best, simplest drop in and go setups for any JDM or EDM DOHC ZC, not so much for the USDM A1 engines, since they have crap cams and even worse intake manifolds.
PostPosted: Sun Feb 12, 2012 11:57 am
:) Thanks for all the input! Especially Acid Beaver with all the tech on "stock EDM PM7 bin in a chipped PM6".
I have a direction to go in, now to get some cash in hand to start the project.
8)
PostPosted: Thu Sep 27, 2012 10:31 pm
8) The Acid Beaver ROCKS!!!! The direction was excellent! Purchased the PM6 (from eBay, it was non-external PROM) and piggy backed a ZIF on the XROM (thanks to the great forum threads found right here on PGMFI.ORG :D ) wrote the bin file to a 29C256 70 NS and dropped it in my CRX Si ZC SOHC and it works great! Improved accelleration rate & smoother power. Next will be bin from CRX SiR... gotta try it 8)
Here are a few pics of my project, wiring could be a little cleaner. This is my first attempt at this. I am sure my work will improve as I go :D
jumper wire in place and ready for EPROM
PostPosted: Fri Sep 28, 2012 12:21 am
Looks great. =)
PostPosted: Fri Sep 28, 2012 10:31 pm
Just got the pics off my digital SLR, the quality is far better than my "dumb phone" :)
I just hope that someone can use this information as I have used what I have found here 8)
Users browsing this forum: Google [Bot] and 20 guests
